Can I add Composer
I am trying to find a way to add composer for my albums using Mp3tag for Mac. I can't seem to figure it out. Also I'd like to be able to select an album and have the composer for each song automatically added instead of doing it manually. Anyone know how to do this?
See the documentation:
will the composer self populate or will i have to add it manually?
Depends how you define "automatically" and "manually".
You can manually call a web source to get tag data automatically.
The biggest chunk of data that can be handled in 1 go is an album.
My goal is to have all songs on an album have composer name. What web source should i use?
I think there is the one for discogs.
You'll have to add it manually. Importing composers automatically is currently not possible.
