Hello
I've been a long time user of MP3 tag, but just had the need to register, cause i have a question
I am trying to move all my multi-CD albums into one folder, and just have my files named the following way [discnumber] - [track] - [artist] - ....
I've used foobar to stick the discnumber tag into the files, but i can't get it to show up in mp3tag, nor do i have any idea how to do a mass rename with discnumber being in the file name
Where did foobar2000 put that information? Select a file and then open the Tags window (ALT+T). If the field name is "DISCNUMBER", you can use "%discnumber%" in the Tag-Filename converter.
ok, this is strange
i've done the alt+t thing, and the discnumber did not show up in mp3tag, even though it was clearly there in foobar.
if i remove it from foobar, and add it using mp3tag, it shows up in mp3tag, but won't show up in foobar file properties, even though the playlist will still recognize it
