Hello, I am trying to rename some files and would like to reorder the name. So as it stands now, the names are like this: element1 - element 2 - element 3. I would like to re-order the names to: element2 -element3 - element1. Thank you in advance for any responses.
You can use either the Convert>filename-filename function
Enter as source: %1 - %2 - %3
Enter as target: %2 - %3 - %1
There is a preview.
Or use an action "Replace with regular expression" for _FILENAME
Search: (.) - (.) - (.*)
Replace: $2 - $3 - $1
Perfect! Thank you!
