I was wondering if my code can be streamlined any more than it is. Quick background:
- I'm writing actions to read and write cuesheet <-> tags. My current, albeit unfinished, code works, so if nothing changes, that's 100% Ok. I'm just looking to learn 8^)
I notice that when I use, for example, $regexp(%TAG%,'(string)', $1), if the string isn't found, the action returns TAG in full. So, when I search for a string to pull a piece of info for tag, I do this:
Field: DUMMY
Format: $regexp(%CUESHEET2%,'.*?REM BOXSETYEAR "(.+?)".+',$1)
Field: BOXSETYEAR
Format: $if($eql(%DUMMY%,%CUESHEET2%),,%DUMMY%)
Like I said, the code does what I want, so it doesn't need to change. But is there any way to make it more efficient?
If you've read this far, thank you kindly for your time 8^)
