Can no longer edit individual fields
Hi Folks. I don’t use MP3Tag super often but I definitely know I used to be able to double click on a field (like Title) for instance when I have a bunch of tracks in the main window and I could edit that individual field, click off and it would save. I can no longer double click to get it to edit the field. Did something change? Thanks!
Nothing changed, can you try a delayed double click, i.e., click, wait half a second, and click again?
Also make sure that the Field is correctly filled in for the respective column (you can check via Settings → File List or by right-clicking on the column header and then Customize...).
Florian! Greatest tech support ever. Thanks so much for the quick reply. That’s exactly it! Geez. Sorry to waste your time! Happy New Year to you!
No problem and thank you for the nice message :slight_smile: Happy New Year to you too!
