Hello
Can not copy & paste from mp3tagv290.
It worked well in previous versions. Please fix
It still works over here.
Are these new files?
Have you got sufficient access rights to modify them?
(It is best if you are the owner of these files - being admin is usually not enough)
I’ve received a similar report via email. Do you have the Filter enabled or are there any other things that trigger this issue?
I've fixed this issue with Mp3tag v2.90a. Thanks for reporting!
