I am re-tagging about 500 live shows and have to import the track names from text files.
The problem is most titles don't simply have a number like 01 - Song Name, instead they have the disc number and track number listed as:
d1t01 - Song Name
d2t02 - Song Name
and so on.
Can some one help me write a string to remove the d1t01 - information? I have been messing with it all night, but I do not understand the programing language.
And it did not remove the d1t01 - part of the file name...Unless I did not put it i the right place.
I am sorry for being such a newb here, but I do not understand any of this code, even after looking through this site and the wikipida page on this programming language.
I select all the songs I want to add track titles to and I use the text import feature, and then simply import my track titles.
The track titles in the text file read as I mentioned above: "d1t01 - Song Name" and so on. So this then becomes my track titles for my selected tracks in mp3tag.
All this works great, I am just trying to find if there is a way in mp3tag to remove the disc / track headers in the program, before that I used to take them out 1 by 1 in the text file and that is taking way too long.
Now the situation is: TITLE tag field is set to a string like "d1t01 - Song Name".
So the TITLE tag field contains three informations:
the disc number
the track number
the title string
For my part I would not like to loose the additional numerical informations, therefore I would do ...
Step 2. Split string from TITLE tag field into three parts and fill tag fields TITLE, TRACK, DISCNUMBER with appropriately content.
Create an action group
Begin Actionsgroup Split_TITLE
Action #1 Actiontype 7: Import tag fields (guess values) Source format: %TITLE% Guessing pattern: d%DISCNUMBER%t%TRACK%÷-÷%TITLE% Note: Replace each special ÷ character with one space character.
End Actionsgroup Split_TITLE (1 Action)
Run this action against the related tracks.
Afterwards the original problem should be solved.
Annotation:
If you make the guessing tag field splitting part of the import process, then you do not need to do a second step via action as described before.
Using "Converter textfile - tag fields" you can set the format string right away as you need it.
The format string "d%DISCNUMBER%t%TRACK% - %TITLE%" (without the quote characters) will split the string line from the textfile into three tagfields.
If you do not need track and discnumber you can code the format string "%DUMMY% - %TITLE%" and it will set only the tag field TITLE.
