Im using Win7 64 bit and Im administrator in this PC
In my last PC MP3Tag worked perfectly (XP)
Now, every time that i try to tag a file gives me this error: "File:C\Music\XXXX cannot be opened for writing.
The files aren`t "read only" and I cannot see the reason of the error.
Can you help me please?
It is not enough to be administrator on a pc - that was the way with XP.
You have to be the owner or grant permissions to "everyone" to access the files for modification.
You can see the owner in the Windows Explorer if you add a column for "owner".
If that columns shows only letter&number-combinations, you should change that to the current user.
Yes I did see those number and changue as the article suggest But nothjing happens.
In XP if you press richt click>Properties>Details was possible add artist or albums names now in 7 I cannot do that, maybe its a windows problem? So far Im searching for an answer (the story of my life).
Thanks for your help
To change the owner:
Select the top folder.
Right-click on the folder and select "Properties"
Go to tab-folder "Security".
Click on the lower "enhanced" button.
Click on the tab folder "owner"
Tick "Apply to all subordinate objects" (my translation - it's the only check box in that dialogue)
Click on "Add"
In the Input box enther most of your current user-id and click on "Check name".
Click on OK until most dialogues are closed again.
Depending on the number of files, it may take a little time until all files have become a new owner.
Probably, once you got the owner right, you will be able to edit the tags in Windows explorer again, yet I would not advise it as WE removes any user-defined fields from files.
