Hello I'm trying to install Mp3tag to a new wds10 computer from an old wds7 comp.
I moved the mp3tagsettings zipped from the old, and unzipped it in the new in:
Users/Me/Appdata/Roaming/mp3tag
I restarted Mp3tag and
well... it don't work , I thought it would restore my tag panel and choosen tags according to my preferences!
Is the zipped backup file include those preferences or what does it keep? and is there a special manip to restore I didn't get?
best
See here for installation and backup:
Thanks
I'm not upgrading and I already read the topic you mentionned, I installed Mp3tag on a new ground and wish to refind the same settings in the above repertory, don't work, I'm doing it step by step now.
best
What you should get clear first of all: what kind of installation do you use? a standard installation or a portable one.
The path that you mention is only valid for a standard installation.
And this statement is valid for both systems: the W7 and the W10 one.
The zip configuration file BTW should show a modification data that is close to the last time you used MP3tag. Otherwise it could be that you do not use the correct configuration.
I'm aware of that, and as I put it, this is a standard install from comp to comp not from comp to key usb.
"The zip configuration file BTW should show a modification data that is close to the last time you used "
that's exactly what I have the datings of cfg and other files or repertories are exactly those of the time I opened Mp3tag.
BUT I have this (Mp3tagError.log)
Mp3tag v2.99a - 15.01.2020 - 11:53:35
OS-Version: Windows 10, 64-bit
Build: Oct 19 2019 10:49:19
AppPath: 207.187.021.824 Bytes frei (C:\Program Files (x86)\Mp3tag\)
DataPath: 207.187.021.824 Bytes frei (C:\Users\PC20\AppData\Roaming\Mp3tag\data\)
TempPath: 207.187.021.824 Bytes frei (C:\Users\PC20\AppData\Local\Temp\Mp3tag v2.99a\)
MESSAGE
File: y:\projects\mp3tag\mtdatabase.cpp
Line: 903
Message: Cleanup covers: 0:00.001913
0000217C at 1d 1:59:48.957244
MESSAGE
Line: 915
Message: Cleanup binaries: 0:00.000027
0000217C at 1d 1:59:48.957304
MESSAGE
Line: 962
Message: Cleaned 0 of 7173 files: 0:00.002804
0000217C at 1d 1:59:48.960138"
anyway I have all of my datas and customized step by step, it works now almost finished
best
