I have been trying for awhile now and nothing seems to work. I am entering $metasep(podcast,\\) in the "Value" line and it appears as a column but nothing I add shows up. What am I doing wrong?
Did you have a look at the help on columns?
And while you are at it: "Scripting" is also a good topic for $meta_sep()
And the list of fields might also be of interest.
You probably need to add %podcast% to Field.
And the correct scripting syntax would also help
vs
$meta_sep(podcast,\\)
