I just found out, that the WS configuration settings window for any web source script I have installed can't be resized with the mouse. For example the Bandcamp Settings window below shows the resize symbol with the mouse positioned over the edge and it has in the lower right corner that marker for being resizeable. But nothing happens when I try to use these resize options.
Is this a bug? What is the intented behaviour of this window?
It should probably only show the resize grip if this indeed resizable.
It has a fixed width and is resizable vertically only if the number of entries exceeds a certain height.
I've implemented this fix with Mp3tag v3.26c.
