Format value: "TITLE": $regexp(%TITLE%,'(\[.*\])',\U$1)
And now I see it has flaw. Because something like this Title 1 [xxx] + Title 2
is correctly changed to Title 1 [XXX] + Title 2
but Title 1 [xxx] + Title 2 [yyy]
is incorrectly changed to Title 1 [XXX] + TITLE 2 [YYY]
instead of being changed to Title 1 [XXX] + Title 2 [YYY]
Apparently the code sees the second >>]<< and so ignores the first >>]<< and second >>[<<
So my question is: how to change it, so it will stop executing itself after each >>]<< and start again after another >>[<<?
And also: how can I find now all the CAPITALIZED TITLES?
The "flaw" could only orginate from an insufficient specification of the pattern that should be dealt with by the regular expression.
I bet that you only supplied one pair of brackets.
Try this:
Format value: "TITLE": $regexp(%TITLE%,'([.])( . )([.*])',\U$1$2\U$3)
You could look for capitals only tracks e.g. with this:
But I don't know how I apparently just forgot to test it on more complicated titles, with more than one brackets
Unfortunately, this also produces the same errors
...eee am I suppose to write down every time the content that is before brackets?
If the problem is the plus sign, that I use when I have more than one song in a file, I could workaround it by replacing it to some other sign or signs before running the main code [and replacing them back after doing so]
No, the $regexp can either have a string constant or a field variable as input. In this case DetlevD chose the string constant as one does not always want to mess up one's track tags....
You can test this $regexp in the Convert>Tag-Tag function.
Format value "TITLE"
$regexp('%TITLE%','(\[.*?\])','\U$1\E')still goes too far, not seeing the end of first bracket
And if there is nothing more after the >>]<<, it just puts
%TITLE%in the TITLE tag
And to prevent further flaws: there can be also other brackets in the TITLE
}But they are [no mater what kind] newer inside other brackets, only sometimes next to each other; for example:
Title A (Sub Title) {2000 Mix} [XXX] + Title B {Club Remix} [YYY] + Title C (Instrumental) [ZZZ][So this is probably irrelevant]
