I would not want to seem too heavy but me to forget there to include the sign: & I have to try of it tinkered with the higher given code but I do not manage to include him. Thank you.
Sorry, I do not understand what you want to say ... and which help do you need.
Try to use Google translator ... translate from your language into english or maybe german language. https://translate.google.com/
... maybe ...
$caps2('S.o.s.','.')==>'S.O.S.'
It has been all said and written down ...
... read the Mp3tag manual help file, ...
....search the Mp3tag Forum ... read the FAQs ...
... try to understand other peoples questions and the answers.
The scripting function $caps has a field where you can define which characters invokes a capital letter should be written.
You can enter the dot there.
You forgot the blank in the $caps2 statement:
'.-&/([' should be
In general I think that the complete replacing stuff is absolutely superfluous.
$caps2(%TITLE%,' .-&/([')
will do the same job.
From:[piano]the fringe(eee)- theme e.e.e.[equation]To:[Piano]The Fringe(eee)- Theme E.E.E.[Equation]Formatstring:$caps2(%TITLE%,'[. ')From: The dune sea of tatooine / jawa sandcrawlerTo: The dune sea of tatooine / Jawa sandcrawlerFrom: The dune sea of tatooine - jawa sandcrawlerTo: The dune sea of tatooine - Jawa sandcrawlerFrom: The dune sea of tatooine(jawa sandcrawlerTo: The dune sea of tatooine(Jawa sandcrawlerFrom: The dune sea of tatooine[jawa sandcrawlerTo: The dune sea of tatooine[Jawa sandcrawlerFrom: The dune sea of tatooine & jawa sandcrawlerTo: The dune sea of tatooine & Jawa sandcrawlerFormatstring:$replace($caps2($replace(%TITLE%,
[Piano] The fringe (Eee) - Theme E.E.E. [Equation]
I would like to be with another example:
[Piano] The fringe (Eee) - Et la meilleur serie | Avec la serie heroes|Avec la serie utopia! Et la serie malcom? Ainsi que/Sherlock homes / Et plusieurs autres\Series de télévision \ Et de cinémas & Court métrage E.E.E. [Equation]
You can find the standard functions $caps, $caps2, $caps3 explained in the Mp3tag help manual.
And also the forum offers help pages with examples how to apply Mp3tag scripting functions.
There is also the function $regexp, which may help in some situations.
The function $regexp needs some knowledge how to create a "regular expression", which defines the rule, how the function should work.
Try to divide your "big problem" into smaller problems.
You can collect several needed steps into one action group.
You can use the action "Tag-Tag" to test your formatstrings, the preview displays the result.
STRING <=='[piano] the fringe (eee) - et la meilleur serie | avec la serie heroes|avec
<!--coloro:#008080--><span style="color:#008080"><!--/coloro--> la serie utopia! et la serie malcom? ainsi que/sherlock homes / et plusieurs<!--colorc--></span><!--/colorc-->
<!--coloro:#008080--><span style="color:#008080"><!--/coloro--> autres\series de télévision \ et de cinémas & court métrage e.e.e. [equation]<!--colorc--></span><!--/colorc--><!--coloro:#008080--><span style="color:#008080"><!--/coloro-->'<!--colorc--></span><!--/colorc-->
STRING <==$regexp(%STRING%,'(\s(?:\S\.)+)','\U$1')STRING <==$regexp(%STRING%,'([].!?&|/\\\\-]\s)(.)','$1\u$2')STRING <==$regexp(%STRING%,'([/\\\\(|[])(\S)','$1\u$2')STRING ==>'[Piano] The fringe (Eee) - Et la meilleur serie | Avec la serie heroes|Avec
<!--coloro:#008080--><span style="color:#008080"><!--/coloro--> la serie utopia! Et la serie malcom? Ainsi que/Sherlock homes / Et plusieurs<!--colorc--></span><!--/colorc-->
<!--coloro:#008080--><span style="color:#008080"><!--/coloro--> autres\Series de télévision \ Et de cinémas & Court métrage E.E.E. [Equation]<!--colorc--></span><!--/colorc--><!--coloro:#008080--><span style="color:#008080"><!--/coloro-->'<!--colorc--></span><!--/colorc--></b><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec-->
