Case Conversion of Title
#1
I'm trying to figure out how to create this action, if it's even possible. The folder that holds my CD rips will have the filename that looks like this:
06-miri_ben-ari-sunshine_to_the_rain_(ft._scarface_and_anthony_hamilton)
On the left side in the title box I would like it to look like this:
Sunshine To The Rain (Ft. Scarface And Anthony Hamilton)
I know I can just do Actions>Case Conversion but that will capitalize everything in the file name, which I do not want to happen. I've tried creating a new action to no avail. I'm also a relatively simple minded individual so any input or instructions should be dumbed down accordingly.
Thanks in advance...
#2
Don't mix filename and title tag. The filename is the identifier used by the filesystem, the tag is inside the file and can be read by dedicated players.
So: if you want to have a title tag then you either have to type it in or import it e.g. from the filename.
If you have a close look at your filename it has much more data in it than just the title. I take it that "06" ist the track number, miri_ben is the artist and then follows the title.
So it would not be a simple case conversion but you have to either strip the heading information or import that, too, into the right tags.
Then also: your filename does not use the "blank" as separator but the underscore. So you probably do want that to stay like it in the tags.
TO sum it all up: the whole action is not a case conversion.
What I would do:
a) import data from the filename into the tags with the Converter Filenname - Tag and a mask that looks like this:
%track%-%artist%-%title%
:sunglasses: remove the underscores
Create an action of the type replace for the tags artist and one for title
(see /t/967/1
on how to create an action)
c) finally do your case conversion, also with an action: case conversion, normal.
If you still have questions about case conversion, there are loads of threads in the forum that deal with case conversion. Search for them.
