Thg6276
November 12, 2014, 7:13pm
1
Good day,
I am using the case conversion (Mixed Case) for having an Upper Case before each word in the title (flac files)
It's running perfectly but there is a problem with title where there is a " 's " inside the word.
For this case I would like to have a lower s.
For example :
I have :
There'S Never A Forever Thing
But I would like to have instead :
There's Never A Forever Thing
How to manage this please ?
Many thanks for your usual help
Thierry
vkostas
November 12, 2014, 10:21pm
2
Strange....
Fiedl: COMMENT
Value: There'S Never A Forever Thing
Action: Case conversion
Field: COMMENT
Case: lower case
Result: there's never a forever thing
2.Case: Mixed Case
Result: There's Never A Forever Thing
Case: UPPER CASE
Result: THERE'S NEVER A FOREVER THING
Case: Mixed Case
Can you try those actions? Please make sure you have the last mp3tag version (you can mention your current version maybe I try once myself).
Check the definition of the action whether the apostrophe crept in as a separator between words.
(When defining the action, you can also set the separators).
Thg6276
November 13, 2014, 6:58pm
4
Thank you for your help
In fact in the case Words begin from/after of, I have indicated : (-'
Apostrophe is mentionned due to the fact that in french we have lot words with apostrophe.
I don't know if it possible to add an Upper case for all the letters except for the 'S.
Thanks
Thierry
Do words in French continue with a capital letter after the apostrophe? I thought it is "C'est" and not "C'Est"? Anyway: you will know better.
You could append the action group where you set the case with a simple "Replace" action where you replace 'S with 's.
Thg6276
November 13, 2014, 9:25pm
6
Great !
Perfect, all is OK with replace action.
Thank you very much
