Case-Converting Only 2 Field Names
Hello,
I have read the FAQ, but I just can't figure this out.
At the moment all my field names are uppercase. I would like to perform case conversion so that only the field names "CUESHEET" and "LOG" become lowercase (so "cuesheet" and "log" respectively). Is this possible?
I have created a new action, I have added a case conversion operation to it, in the field drop down I have selected _FIELDNAME and I have also chosen the lower case option. Is there something else I need to do?
The problem is that all my field names have become lower case and not just the wanted two.
Thanks a million!
It's not possible to apply different case conversion settings depending on the field name. If you choose to apply case conversion on _FIELDNAME it's applied on all field names.
Thank you for your reply, Florian.
