How do you create a column for the iTunes Category column? I have some songs with text in that field, and no matter how much I try I can't remove it. Or find it in MP3Tag. Anyoen know?
If you open such a song (with iTunes "Category") in Mp3tag and then press ALT+T, what do you see?
You would have to force iTunes to write all data to tags.
That data that you then do not see in the tags is probably stored in iTunes' own database and not in the tags. If this is so, then MP3tag cannot do a lot about it.
@psyscope If you like, I can have a look into this track and do a further check with other tools. Just send a PM** to me where I can download your specific song.
** Press on the L-Icon left of my username and send a message where I can DL your song. Of course I delete it as soon as you get my result.
Hello, if you put data in the PODCASTCATEGORY in mp3tag, you can read it in Itunes in the category field. you can only read it in itunes and sellect this field in smart playlists
ggrrttzzz
Guru
@LyricsLover Thank You, I rar'ed a bunch of the songs that have this problem.
See the OneDrive link.
https://1drv.ms/u/s!AsGTZ5IdwW7FsflyfVWdlOgh_EENgA?e=q8LHO5
2 years later?
As @ohrenkino already wrote, there is a high chance that this "iTunes Category" is not an official tag and not written back to your files.
The only tags that Mp3tag doesn't show for your files are some of the type "UnknownFrame", as WXXX or WOAR. Both are NOT related to your question.
And you have 3 pictures (APIC) in your first file. I don't know, why Mp3tag only shows 1 "Front Cover". This is also NOT related to your question.
In Itunes 12.08.1.3 on mac it works just for me
