Pone / Dano I would like to know if it's possible to make (2) modifications to the Web Script Settings:
The Credit tag witihn the Web Script Settings. How to remove the word: Credit from the Web Script update. I can do this manually, but I have to go to each *.src
#< ## ALBUM CREDITS - Main Section #
findinline ""albumextraartists":" 1 1
if " [{"
outputto "CREDITS"
say "\\\\u000d\\\\u000a" (Notice I have removed the word <i><b>Credit</b></i> after Say"
(However - obviously - each time I update the Webscript it adds it back in to the new script.)
Is there a way within the Webscript to make the change.
How to modify the Web Script to add a Broken line after extra artist name (role) .
Extra Artist - Track Credits - Name Variation: >PERFORMERS
name/role format: >role: name
combine names with same roles >no
if more than one extra track artist:
multivalue tag field >no
multiline tag field >yes
list of names >yes
seperating characters used in list >;
Extrafields: >
delete extra fields from main section >yes
Example:
Album Credits:
Stanley Clarke Bass/ Vocals
George Duke Piano, Keyboards
Todd Cochrane, Steve Hunt, Deron Johnson Keyboards
In the setting mp3 file of my discogs web script, go to:
CREDITS; NOTES; IDENTIFIERS; COMPANIES
At the begin, use the following settings:
Combine Credit fields with other fields:
Track Credits Primary Names >no
Track Credits Name Variations >no
Album Credits Primary Names >no
Album Credits Name Variations >no
(If credits are combined with other fields, the script uses an extra headline (the word "Credit:"), if not combined, there is no headline)
Note that there are two different credit/extra artists sections at Discogs: track credits and album credits.
The settings you have posted are for the track credits:
But your example are album credits. For those, go to
Extra Artist - Album Credits - Name Variation:
(also in the ARTIST NAMES field of the settings file).
There, use the following settings:
if more than one extra album artist:
list of names >no
Edit:
I think i misunderstood you. I thought you want a line break. But you actually want a broken line like this: - - - - - - -
I experimentated a little with the script and found out that it is possible. Use the following settings:
multiline tag field >no
list of names >yes
seperating characters used in list >\u000A------------------------------------\u000A
What Mp3tag Version are you using? Your forum profile says 2.45, which is pretty old.
I think \u000A for linebreak was introduced in one of the latest updates. In older versions, you need \\000A, but that is not possible with my export script, because \\ generates a mulitvalue tag field in Mp3tag.
You could also test u000d\u000a but I think that won't work either
