Great program!!
Is there a way to modify the ID3 Input Mask pane/window to include additional ID3 tag fields?
I know I can modify the fields on the "right-hand" side and use View | Customize Columns to add or delete fields.
Thanks.
Great program!!
Thanks.
Thanks for the nice feedback
I'm glad to hear, that you like Mp3tag!
Changing the Input Mask is not possible/planned at the moment.
With best regards,
~ Florian
