If I have a title that reads "Enter Sandman - Metallica", how can I REVERSE it so that it reads "Metallica - Enter Sandman"?
Thanks!
Thanks!
Using Format Value, you'll want to enter
Field: TITLE
Format String: $regexp(%title%,(.*) - (.*),$2 - $1)
As long as your files are all separated by that same hyphen, and only that one, this will work well for you.
Yes!! That's exactly what I needed. Thank you!
