Hi, As a frequent and satisfied user I was wondering when i want to change a name of a track in 1 step.
Until now I did change the filename and also the title because those are not connected.
Is there a faster way ?
Regards, Barry
If you want to change 2 things then you have to do 2 things.
In your case I even think that there is a definite order to make sure that the master data is copied to the slave data field.
But what you could do: change first all title fields then select all files and apply a unifiying action or use a function like
Convert>Tag-Filename
and rename the file with a format string like
%track% - %title%
