When I try to open MP3 tag editor I get this message . . . . . .
The drive or network connection that the shortcut 'Mp3tag.lnk' refers to is unavailable. Make sure that the disk is properly inserted or the network resource is available, and then try again.
I have changed the drive location so it is correct but the application will not open to let me change the default path.
Right-click on the lnk-file that causes the trouble.
Select "Properties" in the context menu.
Enter the correct path in the subsequent dialogue.
Or: delete this lnk-file,
open the Explorer
navigate to the program path of MP3tag
right-press on mp3tag.exe and drag it to the location where the lnk-file should be.
Release the mouse-button and select "Create link" in the context menu.
