I have a folder with 135 mp3's. I was able to successfully change their file name to the same as the Title.
However, there is a small quick that I was wondering can be batched. In the Title, is there a way that I can tell the software:
Change the file name to all 135 mp3's to what the Title of the mp3 is, BUT when you do that, remove the "-P" that is present in every one of the 135 mp3's?
I would hate to have to do this manually.
I already know I can export a list as a CSV file and open in excel, and from there use operators to do this, but I don't know if I can THEN import this back to mp3tag.
