royden
March 28, 2021, 6:21pm
1
how do i change filenames differently depending on extension?
suppose i have mp3 and opus files together
i want to change the file name of the mp3 files to
E:\Music\Mp3%albumartist%%album%%albumartist% - %title%
and the opus files to
E:\Music\Opus%albumartist%%album%%albumartist% - %title%
is it possible without using filters?
Change
and
to
E:\Music\%extension%\%albumartist%\%album%\%albumartist% - %title%
royden
March 28, 2021, 6:29pm
3
thanks!
but what if i want to put the mp3 files in a folder called just E:\Music ?
royden
March 28, 2021, 6:32pm
4
let me rephrase this. i shouldve asked this in the beginning
i want to move mp3 files into E:\Music%albumartist%%album%%albumartist% - %title%
and my opus files into E:\Songs\Opus%albumartist%%album%%albumartist% - %title%
how do i do it all at once? sorry for any confusion
$replace($lower(%extension%),opus,E:\Songs\Opus,mp3,E:\Music)\%albumartist%\%album%\%albumartist% - %title%
royden
March 28, 2021, 6:40pm
6
ohrenkino:
$replace($lower(%extension%),opus,E:\Songs\Opus,mp3,E:\Music)%albumartist%%album%%albumartist% - %title%
for some reason it didnt work : (
Did you check the preview for each file type? (It worked over here ...)
royden
March 28, 2021, 6:45pm
8
do i have to input this into Convert > Tag - Filename
or should i use Format Value - _FILENAME ?
That should be the same, really.
But the Converter shows you a preview first. When you are sure that you have the right expression, then you can use the format value action.
royden
March 28, 2021, 6:48pm
10
ohrenkino:
the preview says the file already exists for some reason
The file "E:\TEST\Eternal Grey$uicideBoy$\Eternal Grey$uicideBoy$ - BREAKDALAW2K16 (feat. Pouya).mp3" already exists.
File "E:\TEST\Eternal Grey$uicideBoy$\Eternal Grey$uicideBoy$ - BREAKDALAW2K16 (feat. Pouya).mp3" has not been renamed.
when i input into convert > tag - filename
I don't know how you end up in a folder called e:\test when the leading part of the filename gets set to e:\music
Could you show me a screendump of what you enter?
royden
March 28, 2021, 6:52pm
12
i made a folder called E:\Royden\TEST to test this out
for the files in there i enter
$replace($lower(%extension%),opus,E:\Royden\Songs\Songs - Opus,mp3,E:\Royden\Music)%albumartist%%album%%albumartist% - %title%
This, again, does not match what you wrote previously,
First it is
royden:
E:\TEST
now it is
So, I think a screendump of the real application of the format string would be helpful in the Converter as that shows the preview.
royden
March 28, 2021, 7:00pm
14
sorry for making things confusing. would you like a screenshot of the convert window?
yes, please.
What I cannot rectify: renaming a file to a filename that already exists will always lead to an error that this could not be done.
royden
March 28, 2021, 7:05pm
17
can i get back to you tomorrow? it is getting late for me. thanks for helping me today
Sorry, I had the wrong variable name: this should work:
$replace($lower(%_extension%),opus,E:\Songs\Opus,mp3,E:\Music)\%albumartist%\%album%\%albumartist% - %title%
royden
March 29, 2021, 6:22am
19
ohrenkino:
$replace($lower(%_extension%),opus,E:\Songs\Opus,mp3,E:\Music)%albumartist%%album%%albumartist% - %title%
bro thank you so much for taking your time and bearing with me to answer my question. it worked. thanks a lot!
