Hello,
I just DLed this application and I checked the FAQs and did a search but I didn't see anything that showed if there was a simple way to change the ID3 tag version. I would really appreciate any assistance. Thanks!
Hello,
Simply select the files and re-save the tags using [Ctrl+S]. They'll be converted to ID3v2.3 (according to the settings at Options > Tags > Mpeg).
Kind regards,
Florian
Thank you!
