Changing metadata from discogs ( style to genre)
I read some of the previous threads on how to do this but is not clear to me how this works.
  1. option to change it in the discogs.inc file in AppData\Roaming\Mp3tag\data\sources .
I’m not a programmer so what do i change? It also seems i cannot save the changed file due to lack of administration rights? It seems i cannot open it as an administrator, but i can open it, do changes but not save it. Or does the program have to be closed to do that.
Then what do i change here ? Is it just outputto “Genre” in “Style” in Genre section and vice versa in Style section (see below)? Thanks
Genre
outputto "GENRE"
json_select_array "genres" -1 ", "
sayrest
Style
outputto "STYLE"
json_select_array "styles" -1 ", "
sayrest
As a new user, consider doing this the easy way, without having to modify a script. A simple Format Value action will load the values in your Genre tags into your Style tags:
To swap GENRE and STYLE I would suggest this form the FAQs:
