Looking to set a rule so if text within title is in parentheses they will be changed to brackets if they contain the words remix, live, mix, edit
So for example, text before would be
Song title (feat. Artist) (Example Remix) Song title (feat. Artist) (Example Mix) Song title (feat. Artist) (Radio Edit) Song title (feat. Artist) (Live at a fictional venue)
After changes it would be
Song title (feat. Artist) [Example Remix] Song title (feat. Artist) [Example Mix] Song title (feat. Artist) [Radio Edit] Song title (feat. Artist) [Live at a fictional venue]
I had a fiddle about with replace with regular expression but with no luck thus far...
$replace(%TITLE%,'(Example Remix)','[Example Remix]')$replace(%TITLE%,'(Example Mix)','[Example Mix]')$replace(%TITLE%,'(Radio Edit)','[Radio Edit]')$replace(%TITLE%,'(Live at a fictional venue)','[Live at a fictional venue]')... or ...$replace(%TITLE%,
'(Example Remix)','[Example Remix]','(Example Mix)','[Example Mix]','(Radio Edit)',
'[Radio Edit]','(Live at a fictional venue)','[Live at a fictional venue]')... or ...$regexp(%TITLE%,'^(.+?)\s(\(.+?\))\s\((.+?)\)$','$1 $2 [$3]')... or ...$regexp(%TITLE%,'^(.+?)\s(\(.+?\))\s\((.*\b(?:remix|live|mix|edit)\b.*)\)$','$1 $2 [$3]',1)
Your screenshot shows, that there is no text in the column "Title" or in the column "Filename", whose format is conform to your order description.
Using the proposals from above you can change text ...
To:
The given text string has to be structured into three parts ...
text (text) (text)
.. then it will be converted to ...
text (text) [text]
Because your text strings do not match the wanted function, ...
there is no change, and this is good, therefore the text strings remain untouched.
So the functions are working properly.
Ah. I see
I think i was misleading then, albeit unwittingly, in what I asked originally.
What I was actually looking at what to do was to change parentheses to braqckets if the text within the brackets contain the words mix, live, remix, or edit etc.
is that possible, I think it is but currently stuck figuring out where to begin.
I'll have a go at tweaking what you posted earlier but if you could point me in the right direction that would be most helpful and I would be extremely grateful.
$regexp(%TITLE%,'\(([^(]*\b(?:remix|live|mix|edit)\b[^)]*)\)','[$1]',1)From:Brains Out(live)Song title(name of mix)[Acapella]Title(aaa Radio Mix bbb)(EDIT)name of song(name of mix)Song Title(feat. Xyz)[Abc remix]To:Brains Out[live]Song title[name of mix][Acapella]Title[aaa Radio Mix bbb][EDIT]name of song[name of mix]Song Title(feat. Xyz)[Abc remix]
