This is a pretty basic function but for some reason Im a bit stuck. I have a compilation album with various artists. I would like to simply change the title of each song to artist-title. I didnt think this was going to be too difficult, but something just isnt working properly. My action is:
Format value "TITLE": %artist% - %title%. At this point, I would even be happy if I could get the title to be the filename. Can someone kindly help me figure why my action is not working?
You don't say what the action is doing when you run it. What does TITLE contain afterward?
That should work, as long as the TITLE field does indeed contain the title and the ARTIST field contains the artist. When you do get it working you'll have to be careful that you don't run it more than once or it will keep repeating the artist name in front.
Is this what you are entering?
Action type: Format value
Field: TITLE
Formatstring: %artist% - %title%
What I do and a lot of other users do is leave 'VA' or 'Various Artists' in the %albumartist% field. If you use other programs it sometimes comes as %album artist% with a space in it.
Then add the value '1' to %compilation%. And leave the artist as is.
Its up to you, but the above action works fine for your needs.
I don't think he's looking for a way to organize his compilations, but just having difficulty with the Format Value function when trying to rename the tracks.
@sbkurtz: Does anything at all happen to the title after you run your action? It looks like your format is right (assuming the tags are filled, as JJ said), so I'm curious, too, why it's not working. ![]()
Thanks all. This is correct - The action is:
Field: TITLE
But when I run this, all I get is: Formatted tags in 12 of 12 files. 0 of 12 files renamed.
Nothing actually changes when I run the action, the TITLE does not change at all.
Its a headscratcher
at this point, I would be totally happy just converting the title from the filename but that doesnt seem to be working either
Can you select one of the files and manually change it?
Are you trying to rename the files or are you trying to change the TITLE field in the tags (or both)? The action you've shown will change the TITLE field, not rename the files.
To rename the files:
Field: _FILENAME
Format string: %artist% - %title%
But most people also want to prefix the filename with the track number, so that files will be sorted in track order when viewed in Windows Explorer:
Field: _FILENAME
Format string: $num(%track%,2) - %artist% - %title%
I can manually change it just fine, but I have a couple of these albums and I wanted to try to automate it. Interestingly, I tried the action below on other albums and it just doesnt seem to work at all on anything.
Field: TITLE
I did try the other action for renaming the file (below) and it does work
Field: _FILENAME
Im running 2.49 which is the latest version. Can anyone confirm that they can run the original action on this version?
Field: TITLE
Please answer the question above. What are you actually trying to do - rename the file, set the TITLE field, or both? You seem very unclear about what you're trying to accomplish. Or, at the very least, you haven't explained it fully.
Yes, the original action works correctly in 2.49. It would be a major bug if it did not. You haven't clearly explained what the action does on your system. Does it doing nothing, or does it give you unexpected results? There's a large difference. Give us an example or two.
I thought he explained it very clearly in his first post. He wants to change the TITLE tags on his compilation albums:
[quote="sbkurtz, post:1, topic:12597"] This is a pretty basic function but for some reason Im a bit stuck. I have a compilation album with various artists. I would like to simply change the title of each song to artist-title. I didnt think this was going to be too difficult, but something just isnt working properly. My action is: Format value "TITLE": %artist% - %title%. At this point, I would even be happy if I could get the title to be the filename. Can someone kindly help me figure why my action is not working? [/quote]It was only after he reported back the response he was getting, the typical kind of mp3tag message...
...that you brought up changing the filename. He never said he wanted to do that. But he did say that message was the only result he was getting....and there was no change in the TITLE at all.
@sbkurtz: Just for sh***&giggles, could you try performing this action on some other album....just any album that you've never had a problem with? (You can always hit UNDO and change it back.)
I have absolutely NO idea whether this problem you're having is related at all, but I have had an ongoing issue that, every once in awhile, an album comes up that won't let me reformat the track number. Just completely random....I can't pad with leading zeros like I do on all my other albums. When I brought it up here, the thread eventually died because no had any explanation or solution.
I'm just curious to see if anything about this issue you're having is similarly album-specific, or if it's a universal problem with mp3tag for all your albums. (Another interesting experiment would be to see if you can perform any other reformatting action on the titles.)
Progprog, You are exactly correct. Oddly, I cannot change ANY album using the original action of (below):
Field: TITLE
Im using Windows 7 with Mp3tag 2.49. Is anyone with a similar config having the correct results with this action type?
Yes, absolutely. I tested it right after your first post and I had no problems performing that action and changing titles to %artist% - %title%. I have that exact same configuration.
What kind (codec) of files do you use?
just regular old mp3's. Ive tried a couple of actions and they seem to work ok but this one is weird. Thanks for your input
Sorry to get myself involved: my all-time favourite: do these tracks have APE tags? If so, it could be that you actually have edited the tags but never written them (or see the modification).
Either use a filter with
%_tag% HAS APE
or define a column that shows the tag version.
If these files have APE tags then remove them.
And adapt your settings for reading, writing, deleting that you don't read or write APE.
