Is there a way to bulk change Track numbers such a 1/27 1/28 to 1 and 28 keeping the track number but deleting the /27 and /28?
Try Convert>Tag-Tag for TRACK
Format string: $num(%track%,1)
Thanks for the suggestion but this just changed the tag to 1. It looks like the right area though so if the track is 1/26 I want to convert it to 01 i.e put a 0 in front of the 1 and delete the /26.
If you had said so in the first place ...
Format string: $num(%track%,2)
Perfect Thank you very much and apologies for not being clear first time. I've just started the 7 day trial of the Mac version so its all quite new to me. I used to use Puddletag but I've now got a Mac. This looks very good and I expect I'll buy it.
Thanks again for your help
