Is there a way to query the number of embedded images?
I am also looking for a way to test the embedded image for a square aspect ratio via script. I would like to delete or load another picture via script.
How can this be done?
the number of embedded picures can be queried with the property variable %_covers%. You could create a column with it and sort by it.
The dimensions of a picture can be seen in
| %_cover_height% | Cover height of first cover art in the tag of the file in pixels |
| %_cover_width% | Cover width of first cover art in the tag of the file in pixels |
You find more information about other variables that may be of interest in this context in the help:
Or use a filter, e.g.
%_covers% PRESENT
%_covers% GREATER 1
That solves my problem, I didn't knew these variables.
Thank you.
