The latter part of my filter falls far short anyway, because the filenames may contain more than just one dash. I am unable to fix this. The result should provide a list of all the files in which the %discnumber% is "1" — but not those where their %_filename% contains a dash "-" anywhere in a numerical string, for e.g. 99-03, 1-02 10-15, etc.
I have tried that as well, but it does not achieve the result I want since there are more than one dash in the filename, and I need only those filenames that contain a dash in any numerical combination as shown. Sorry if I am not expressing it well enough. Example:
1-01. Starboard - Just The Way It Is.mp3 15-24. Starboard - Only This.mp3
(The dash in the 1-01 and 15-24 is the one needed for the filter. But, its position within the numerical number is not a constant.)
Sorry, I have made a mistake. Your given syntax works fine. I am not sure how it does, and will try it out some more ahead to see if it takes care of all possible dash-variables.
Once again, I am stuck for a filter-syntax, and needing your expertise in the field. I think this belongs to this particular topic, but if you disagree I shall create a new post for it. This too, is a follow-up question to this thread:
My current combined filter, thanks to you previous input, looks like this:
%discnumber% IS 1 AND NOT %_filename% MATCHES (\d+\-\d+) OR %albumartist% IS various artists OR %_filename% HAS (HTOA) OR %album% IS Unknown
My objective now, is to add a filter with which to identify those albums that ought to have "Various Artists" in the %albumartist% field, but do not. These occur rarely, and are therefore easily missed. Without elaborating further, I can point that the only constant by which I can identify these albums is that they have the %artist% name in the filename, already.
Thank you.
PS. Would this, perhaps, achieve the goal? %_filename% MATCHES (\d+\%artist%\d+)
The Logical Operator functions AND, OR, NOT add greater flexibility to the filter. These are discussed in the documents for filters.
Usually it is the AND function to reduce the number of filter hits by being more specific. The OR function widens the net. NOT is used to invert the result.
@ohrenkino already provided the filter for the first statement. This can filter for the second. NOT %albumartist% IS "Various Artists"
Combine these two filters with AND to have both applied to your desired results.
