I was wondering if there was a way to make the program read chinese characters.
I was using an action code to get my artist/title from the filename, but the chinese characters ended up showing up like ???
thanks
thanks
If you have mp3 files you must use one of the utf options at Options > Tags > Mpeg
thanks, works perfectly
Hi, I use it for a very long time and seems no trouble in MP3 file. Recently, I am trying to edit some WAV file and I find all the Character come to "?" (File property, under Windows 10, also move those file into Sony DAP) , I have try all Mpeg option under Tags, but it is no help, any idea?
