Hi all
i was wondering if there is a way when renaming/moving files (ie using the tag to filename) to delete the non audio files (such as *.txt. *.cue, *.log etc)? is that possible?
thx alot
Z
Hi all
thx alot
Z
MP3tag only treats the files that are currently loaded.
You could expand the list of treated file extensions in File>Options>Tags.
You would have to delete files manually from the list, though.
There is no action or function that deletes files automatically.
(I assume that this is a question about general MP3tag functions as known from the Windows version and not one about specific Mac version features.)
thx @ohrenkino !
i think (unless im missing something) this isn't implemented on the mac yet (i use the mac version)
thx again
Z
