Clean up filenames
Hello,
I did use lot of this program back in the past and remember that there was some function to “clean all filenames”. So let’s say that you had a filename that was wrong like this:
”01-W.A.S.P. -Love Machine” and it should be “01 - W.A.S.P. - Love Machine” it did correct every filename with a regular impression. With this function it was easy to clean the whole library at once.
Is this function still available as I can not find it?
I would use Convert>Tag-Filename and rewrite the filename in toto with e.g.
Format string: %track% - %artist% - %title%
Are you referring to the $validate function?
From the String functions part of the documentation:
$validate(x,y) returns the given file name/path x with all invalid characters /?*"<>|: replaced by the string y.
If you want to replace a single hyphen with "space hyphen space", then a simple "Replace" should be enough.
Also, see here:
Thank you once again for good hints!
