Hi! Any possibility of adding a function to collapse/expand columns like MS Excel? It would be useful for a better workflow by hiding/showing certain columns at will to do some actions instead of select/unselect columns from the menu ony by one every time you need it.
Cheers!
This is not necessary, although I appreciate your suggestion.
Right now you can create and save a variety of preset column layouts for use when needed. In the Columns dialog is a button that enables you to save and/or load these layouts (see the screen shot below).
Well, that's a practical workaround. I was thinking in this suggestion like a way to avoiding extra steps to achieve the same goal, but putting it like this, it makes sense. Thanks for your attention anyway, I appreciate it
