hi
I have an mp3 album that shows the mp3tag "Tag" column as per the topic title and I'd like it to be the same as my other albums e.g. ID3v2.3 (ID3v1 ID3v2.3), assuming that is the right standard to aim for. I know ID3v2.4 exists but that seems to be not very widely supported.
So, am I correct to aim for ID3v2.3 (ID3v1 ID3v2.3) and does this mean that the v2.3 tags are written at the start of the file and the v1 tags at the end of the file.
My options are set as follows in options-tags-mpeg:
read id3v1 id3v2
write id3v1 id3v2 (id3v2.3 UTF-16 ticked)
remove id3v1 id3v1 ape
I've tried updating tags with a dummy change but the apev2 is not removed.
Is there something I can do to get rid of the apev2?
using 2.61d beta
