For classical music collections, I prefix each title with the capitalised surname of the composer.
I store each composer in the format "Surname, Firstname etc"
In order to do this right now, I do the following
- Replace TITLE with $upper(%composer%) - %title%
- Filename is set to %track% %title%
- Use Filename converter as
OLD: %1 %2,%3 - %4
NEW: %2 %4
- Split the Filename to track and title
Example: Track #3 Title "Moonlight Sonata", Composer "Beethoven, Ludwig van"
- TITLE -> BEETHOVEN, LUDWIG VAN - Moonlight Sonata
- FILENAME -> 03 BEETHOVEN, LUDWIG VAN - Moonlight Sonata
- Filename-> 03 BEETHOVEN Moonlight Sonata
4.TITLE -> BEETHOVEN Moonlight Sonata
And what do you do with the different "Bachs" and "Mozarts"?
Anyway, you could use a separate tag-field (ie. selfdefined) for your short form of the composer. There is also an official tag-field called COMPOSERSORT.
That at least would it make unnecessary to mingle with the filename.
All could be done with 1 action group:
Action: Guess Values
Source: %composer%
Formatstring: %composersort%, %dummy%
Action: Format Value
Field: TITLE
Formatstring: $upper(%composersort%) - %title%
Field: _FILENAME
Formatstring: %track% %title%
Thank you
I generally do something like BACH.CPE, MOZART.L or SCARLATTI.A for the "lesser of that name".
