Congratulations on an excellent program.
I sometimes rip an album as one single track. I then use the comment field in the ID3v2 info (Winamp) to list the tracks (and times). When I attempt to do that with Mp3tag I only see a piece of the comment. Can you help me get the entire list to appear?
Thanks
RC
Mp3tag uses the part before the : character as description for the ID3v2 comment field. If you use the : character in the comment fields, you'll only see the part after the first colon.
Best regards,
~ Florian
So i can lead with a : and everything else will be a comment?
Cool
thanks
RC
