Comment lines in Action groups?
I've made an action group of changes I commonly make to tags. Now and then, I don't want a particular action in the group to execute. Is there a comment character available that can exclude an action without deleting it from the action group?
I looked in the help briefly but didn't find such a thing.
No, there is not.
The only way would be to separate the actions into action groups and then join them by ticking the check boxes in the Actions dialogue. Is a different concept, though.
Alternatively, you could duplicate the whole Action Group to a new temporary one and delete the unwanted Actions there. To quickly spot the right Actions it helps to create artificial separators, e.g.
Remove fields ••••••••••••••• ACTION XXX •••••••••••••••
Thanks for the suggestions! Certainly they are good ways to go.
A comment character such as ";" or "#" or "/" when found in column 1 would be a useful improvement.
