Since I noticed the Energy algorithm of Mixed In Key is so-so, (and what about Genres nowadays...)
I began to incorporate my Mood, Energy & Genre tags manually.
This can be a tedious job, so I finally found a straight-forward solution using foobar2000 with a tagger component & mp3tag.
Tagging genre, mood & energy in 25 seconds per track!
How do I get POPULARIMETER(Star-rating) filled in 1 star, when COMMENT field contains [EN]Low ?
How do I get POPULARIMETER(Star-rating) filled in 3 stars, when COMMENT field contains [EN]Mid ?
How do I get POPULARIMETER(Star-rating) filled in 5 stars, when COMMENT field contains [EN]High ?
You could create an action of the type "Format value" for POPULARIMETER
Format string: $replace(%comment%,[EN]High,*****,[EN]Mid,***,[EN]Low,*)
and then an action to cut away the [MO... part:
Action of the type "Guess value"
Source: %popularimeter%
Target: %popularimeter% [%dummy%
Woah - hold on there? I thought TRAKTOR4 was not viewable in MP3Tag?
I notice that you are using FLAC files. Is it the case that MP3Tag can only read TRAKTOR4 tag if it is attached to a FLAC file? Because I've tried with .mp3's and cannot see TRAKTOR4...
