comment tag lenght
i want to merge the unsyncedlyrics tag and the year tag.
i use the ottodestruct script to write the lyrics in the comment field instead to the lyrics one, so i can, via an action, merge year and comment to the unsyncedlyrics tag.
all is working well.
i'm only wondering if there's a limit to the lenght of the comment tag, and if i'm risking losing some piece of lyrics in the action.
thanks
i answer myself. it's gonna be truncated at some point.
how do i manage to merge two fields into unsyncedlyrics? i tried with unsyncedlirycs1 and 2 but the "eng||" part won't allow that....
thanks
i answer myself again... i manage to get through via an action with replace regular expression
now i have the unsyncedlyrics that displays:
Year: YYYY
one carriage return and then the lyrics itself.
the action menu is very powerful.... thank u.
if anyone has the same problem....
[#0]
T=5
F=UNSYNCEDLYRICS1
1=%unsyncedlyrics%
[#1]
T=9
F=unsyncedlyrics
[#2]
T=2
F=UNSYNCEDLYRICS1
1=eng||
2=
3=0|0
[#3]
T=5
F=UNSYNCEDLYRICS2
1=%year%
[#4]
T=5
F=UNSYNCEDLYRICS
1=YEAR: %unsyncedlyrics2%$char(13)$char(10)$char(10)%unsyncedlyrics1%
[#5]
T=9
F=unsyncedlyrics1;unsyncedlyrics2
i was searching to show in the ipod the year tag and then the lyrics. this works.
You can do it in one step:
Action type: Format value
Field: UNSYNCEDLYRICS
Formatstring: Year: %year%$char(13)$char(10)$char(13)$char(10)$replace(%unsyncedlyrics%,eng||,)
thank u.... i'm a newbie at this kind of thing.... i have done it step by step
