Comment zone in MP3 file
Hello, I don't know if this is just me, but for the past few days I've noticed that the data I enter in the "Comments" field is no longer being saved in my MP3 file. When I check my file settings with Explorer, the "Comments" field is empty. Could you tell me if I'm the only one experiencing this problem, and if so, do you have an explanation or a solution to get it working again? Thank you.
Please see File → Options → Tags → Advanced and use an ID3v2 comment language code that matches the locale of your system. It could be fra if you're using a French Windows.
I've also removed the two other languages from your original post, English is sufficient here.
Check the language settings in Ctrl-O Tags>Advanced.
They would have to reflect the OS language.
Perfect, thank you, it's working again now.
Perfect, thank you, it's working again now. Merci
