Hi there!
Is it possible to make the default Comments edit field multi-line, e.g. 5 lines high?
Hi there!
yes. a bit tricky but it works:
Multi-line comment box
Hi pone, thank you for the hint! This works, although I would wish to have this INSTEAD of the default field which is now doubled which is a waste of space.
Also, it would be nice to be able to customize the size of the album image.
You may add an user defined edit field to the Tag Panel and later on copy the content into the standard comment tag-field.
See picture ...
DD.20111026.1548.CEST
you can also click on the extended tags button (alt+t)
edit comment field
ctrl+enter for next line
