Whenever I get freedb data for compilation CD's, its tedious to manually separate it. I found that there was a feature to automatically separate it, using the compilation box.
I used the (default) pattern "%artist% / %title%", and it doesnt work. Artist turns to various, and title is blank, even though the data is correct. Here is some sample data (directly from freedb preview) that produces the symptoms (looks normal to me!):
Don't know how %artist% and %title% had appeared in the new version, but they do not work
Use "%i for artist and %t for tracktitle
Or press F1 being at that dialog
