I want to achieve a conditional guess.
source tag %album% needs to be interpreted as 2 tags %album% (%setsubtitle%) . I.e. Deep Purple In Rock (Anniversary Edition) would be split in Deep Purple in Rock and Anniversary Edition . Executing 2nd time the script shouldn't do a new split otherwise the 2nd tag will be overwritten.
I tried
$if(%setsubtitle%,%%album%% (%%setsubtitle%%),%%dummy%%)
but it didn't work.
Maybe what I want could be done using temporary tags but I have the feeling conditional guess is feasible. Probably I don't use the correct syntax.
Thank you.
DetlevD
January 10, 2011, 10:05am
2
Feelings can be deceiving - but bad syntax is always right - it simply does not work.
A first help can be to set the Mp3tag Filter [F3] using this expression:
"%ALBUM%" MATCHES "^.+? \(.+?\)$"
This reduces the list of files to show only possible candidates.
You can use an action ...
Begin Action Group Test 2011#20110110.VK
Action #1
Actiontype 7: Import tag fields (guess values)
Source format: %ALBUM%
Guessing pattern: %ALBUM% (%SETSUBTITLE%)
End Action Group Test 2011#20110110.VK (1 Action)
DD.20110110.1214.CET
You can use two actions "Format value" ...
SETSUBTITLE <== $if ( %SETSUBTITLE% , %SETSUBTITLE% , $regexp ( %ALBUM% , ' ^(.+?)\s\((.+?)\)$ ' , ' $2 ' ) )
ALBUM <== $regexp ( %ALBUM% , ' ^(.+?)\s\((.+?)\)$ ' , ' $1 ' )
DD.20140910.1118.CEST
