Does anyone know if it is possible to use one Conditional Format String action ? I basically want to change teh 'band' value on tons of songs, but I want it to be changed only for certain genres.
I would like to have the Band name be equal to the Artist if the Genres are one of the few I ahve, and I would like to have Band value be equal to Album for some other etc.
Thanks. Sounds like you are saying if genre equals Rock or Pop, then band = artist. can I also add else clause in this or do I have to add a separate action for that ?
instead of creating a conditional action, you simply could sort/filter your songs by genre, select the ones you want + apply a simple format value action !?
True - that is what I have been doing, but if I have a fully working action with conditions than it makes it all the mroe simple to when I work with batches of folders that I am cleaning up (for my Zune)
I've ended up aking two separate actions, one for BAND = Artist, and anotehr BAND = Album, and pick and choose one of them for every directory that I clean up.
But would love to add the "if then else" in one action itself..
So you just have to repeat the whole thing:
$if($or($eql(%genre%,Rock),$eql(%genre%,Pop)),%artist%,$if($or($eql(%genre%,Jazz),$eql(%genre%,Metal)),%album%,%band%))
@Harakiri:
It's not possible to check if an album has one or several artists within an action.
But it's possible with the export, generate a txt file and import it back to the tags, then rename based on the new tags.
