Context Menu and Adjust Cover
Hi.
MP3Tag could appear in Context Menu.
Adjust Cover could have pixel adjustment.
It does if you set the option during the standard installation.
I don't understand what you mean by that.
Adjust cover in pixels
Do you mean this feature?
Exactly.
MP3Tag has kilobyte adjustment. It could have pixels adjustment.
According to the documentation, this is not correct:
Sorry.
Max. Size changes Pixels and Kilobytes at the same time.
I think that is the usual behaviour: if you reduce the number of pixels, then less space is needed to store these.
I think you can save a picture with reduced quality but the same dimensions - this would also reduce the size in bytes.
It does not work the other way round: reduce the number of pixels but increase the quality to keep the size in bytes the same.
Thank you.
You are very kind.
