OS: Windows 10
When I right click in Windows Explorer on a folder the option 'Mp3Tag' appears. Can you edit it so it only appears when you click on a folder OR on it only appears on .mp3, .flac, .wav (audio) files. Maybe in the settings a checkbox with the music formats and folders.
I don't want it to appear when i right click on a .mp4 video for example.
Thanks!
Use a "context menu editor" like CCleaner** to choose when Mp3tag (or any other program) appears on a right click.
**CCleaner:
Tools -> Startup -> Tab "Context Menu" -> Enable, Disable or Delete context menu items which are needed or no longer needed for a directory, a drive, a folder or a file.
Or if you prefer the manual way:
Just to add an alternative:
https://www.nirsoft.net/utils/shexview.html
