Convert error (Reference Alt+1)
when i click CONVERT, then TAG-FILENAME (alt+1), I am given an option of several things that I have created…
however, there comes a time when these things are not needed any longer
is there a way to remove previous tag-filename options? or history?
20260213 mp3tag issue
clicking DELETE does nothing
right clicking does nothing
left clicking selects the item
Click on the right-facing arrow button to the right of your drop-down box.
and then click on the last entry
Manage history
There you can adjust, duplicate, rearrange and delete all your entries. It should look like this:
thank you!
that worked perfectly
:):grinning_face:
