Hi there all,
I have added a custom filed "%release type%" to my all collection.
Now i want to convert the field into "%release%" without deleting the info..
Thanks in advanced
In a way you have to delete the information - after you have saved it:
Create an action group with 2 actions:
First:
Format value for release
Format string:%release type%
Second:
Delete field: release type
you are very kind sir
thank you very much
